would a 1.6 k series engine from a rover 45 go into a rover 416 without any tricks?
what parts are different between them?
If the donor engine is post 99 ( iirc ) it has plug top coils and is distributor less. Your original engine has a dizzy cap. Techincally it will go in but you will have to swap components to make it all work.ie exhaust cam , unsure on flywheel, but use the original one you will be ok.
