1 - 17 of 17 Posts
Hi can someone show me a pic of where the wire for the amps power comes through the bulkhead into the car. Also how many metres will i need to get to the boot?
Cheers Harry
To get to the boot, you'll probably need 6meters tops.
The cable can be bought in on the passenger side. There is a gromet just below the expansion bottle, where the main loom goes into the car. It can be pushed through there.
I would think 4 meters would be enough, but I prefer to have a lot of extra cable tucked away just in case I want to move things around, need to re-terminate etc.
What i'd do is take a rough measurement of the route you will run it along, and then add a bit.
I'd go for 5m just to be on the safe side.
I ran 5m through mine and have a fair bit spare but it depends where you put your amp. You might be hard pushed if you want it on the other side of the boot with only 4m.
Discussion Starter #6
im not really bothered where it goes but ive spent all my money on the amp and sub so now im trying to save a bit on the install so 5 metres will definately be enough
Buy an amp fitting kit. Has all the correct wiring and fuses you need.
They cost from £10 upwards (depending on where you go and the core size of your Battery to Amp lead).
Discussion Starter #9
yeah i would buy a fitting kit but i really need to do it tomoz as i dont have any time after that for about another week and i dont want to wait that long and the only place i know of to get a fitting kit for 10 quid is the internet unless anyone knows of a place somewhere in telford?
get ya self along to halfords and buy the fusion wireing kit that i belive was £35 when i got about 6months ago
is a great kit - comes with all you need and power cable is plenty long enough
Discussion Starter #12
I got a kit from a local car shop in the end and put all the cables in expecting the sub and amp to arrive by the time i got home but it hadnt. it did arrive this morning tho but i had to go to work so will connect it all up in a bit. Anyone got any tips on securing the sub enclosure in the boot?
Cheers Harry
mg_zt
i found the grommet do i have to cut a hole in to it?? were abouts inside does it come through??
sorry for hi-jacking the thread
Yeah, I just shoved a bradall through then fed the wire through. If you take the glovebox out it makes it much easier to find the hole.
When I did mine, I pushed the bradall through, then left it in and felt around from the passenger side, to try and locate where the wire would be coming through. Then I fed the wire through the hole after removing the bradall.
I wouldnt secure with velcro again, did it with some heavy duty stuff and it moved under heavy braking - I scoffed when I was told it would - i'd hate to think what it would be like in an accident! :err:
1 - 17 of 17 Posts
