1 - 5 of 5 Posts
Is there any way I can wire the electric windows in my 416 to automatically roll up when the lock button on the keyfob is pressed?
Mmmm....Rover..
I did it on a Mk3 200, however it is complicated somewhat on the 400's as power is immediately cut to the window circuit on switching off the ignition.
The Mk3 200 keeps the window circuit powered for approx. 60 seconds after ignition off.
Solving this first problem on the 400 entails stripping down the fusebox assembly, it's rather involved.
Mmmm....Rover..
I built a circuit with two relays, they operated for a timed period and were activated from the alarm ecu C/L output.
The relays effectively replaced the action of someone pressing both window buttons simultaneously.
1 - 5 of 5 Posts
