I think the only place on the 600 where there is a rust problem in the leading edge of the rear wheel arches. Does anyone have any ideas why they go like they do? I suspect that the rust starts on the inside and that water somehow gets in and collects there?
B
It's because Rover never offered us that particular replacement panel :(
MGJohn directed me to the Honda Accord sedan panels from the USA when mine went scabby.
Replacing two panels of that size sounds like an expensive thing to do and it that doesn't cure the underlying problem.
It has to be a water trap problem of some kind
Discussion Starter #4
Replacing two panels of that size sounds like an expensive thing to do, especially when it is such a small area and nor does it cure the underlying problem. It has to be a water trap problem of some kind
Rover 620ti
I was always under the impression its because of the sunroof drains, the ones on my ti where leaking having become blocked, leaving water in the boot which inevitably turns to rust, always keep an eye on them as leaves and all manner of things you dont think would get in there manages to
Another area these like to go is under the front floor, there are 4 rubber bungs (2 each side) underneath the car roughly at the front of the driver and passenger doors next to the jacking points, these hold crap in too and they rust through this area
Another semi-common area i have found is around the rear windscreen, remove the chrome trim and rubber surround and all the clips along the bottom of the window are most likely hiding rust
The rear arches are by far the worst area for rot though
Discussion Starter #6
I don't think it is the sunroof - my 620SLi doesn't have one. But I feel sure that water gets trapped inside the body panels and the rust goes through to the outside, which means that there's no real way of avoiding it. After repair as best possible with filler, ensuring that there's a drain hole might help?
Hi people since i own 2 rovers 600 series i will tell u that way even if u manage to get new panels
and find someone to weld them paint everything - - if you still drive your car- i drive my cars daily all year around winter, summer, rainy days
rust will arrive soon in few years maximum so u must do it again and its a costly procedure just to let u know be preparate if u like the car spend a lot of money.
Both of my cars are rusted badly and i repair them in period of few years,
1st of my cars i drive for 10 years in a ROW, it doesnt have sunroof,
simply these cars doesnt have good anti rust protection thats the fact story - they had once the car was new but over time protection is gone, also if the car was driven all year round and not stored in garage it rusts really really badly my cars are parked into the street all year round.
