1 - 18 of 18 Posts
ever since i brought the car i've noticed a whistling noise coming from the drivers side window, it only happens at motorway speeds and if you push on the glass at the top the pitch changes so im guessing either the window seal is at fault or the window itsself is not going all the way to the top. Any ideas how i could fix the problem?
many thanks in advance
mgf
Yes! Your are not alone, what the hell is this ???
Have you noticed that many cars have a little lip near on the curve of the door to divert rain and air away, I think it might need something like that added...
I have the same problem on my zr, i think the window has slipped as it doesnt always line up with the seal, and occasionally the seal becomes bent under the window and i have to put the window up and down a few times until this sorts itself out
yeah i know what your talking about onuo, you can get them on ebay, wind deflectors there called. a guy fom germany sell ones specially made for the rover 200
although this will solve the noise problem, the security aspect still remains that there is a gap in the window, some one could slide a flat door opening tool in and get inside!
Not in my car, my central locking knob on the drivers side is nackered s no chance of them getting in, or me getting out in the event of a fire
mg_zt
My window doesn't go into the seal properly at the top, and I get this same whistling. AFAIK you can take the door card off and tighten the glass up, I will be trying this tonight hopefully.
thought ide add myself to this as i get it too.. first i thought i had a puncher in my tyre then thought maybe my brake pads were rubbing but no to both and its still there...
mgf
Technozone! I've noticed you've linked to alot of interesing things on your ftp in previous posts, is there any way to scroll through the docs to have a look or is it all private ;) - just wondering and I'm a nozy sod !!
mg_zt
Nice one.
I know it's a 400, but I had my door card off last night, and it looks like I need new window seals all round.
Is this anything to do with the fact if its been raining and the windows have beads of water on them, unlike most cars, if you wind the windows down, it doesnt get rid of the water, as the glass doesn't seem to touch the door?
I don't get any whistling, but its a pain when I can hardly see out of either side window... any fixes?
I get the whistleing aswell!!
It took me ages of playing around with the sun roof to realise it wasn't the cause.
As above - window up and down a few times seems to realign whatever is out and it stops.
mg_zt
I fixed mine
Took off the door card.
Loosened all the bolts for the window mechanism.
Put window near the top and jammed it over to the straight side of the window.
Tightened bolts.
Done
1 - 18 of 18 Posts
