I guess its not the plastic one!
if you had a donor vvc would it be simpler to remove head and manifold and fit to 214? or would this not work?So, The VVC manifold would have to be port matched to a non-vvc head?
What about the metro GTI manifold?
metro manifold is cast aluminium, far too expensive to keep that, changed to a plastic one instead.Not looked at the Metro one.
If it was any good they would have used it for the Zeds.
I don't see how you can obtain better driveability from a larger TB. A larger TB tends to make the drive a bit more twitchy.I swapped to the 56mmtb from the ZR one to find it has better drivability.
I'm sure the Metty one is far superior, hence they used the larger TB.
