1 - 20 of 22 Posts
£16.50inc vat from RimmerBros. I would try cleaning the connections for the Idle air control valve and Throttle position sensor with some contact cleaner first though, this cured the high and occasionally fluctuating idle issue I had.
Discussion Starter · #8 ·
This seems a little far fetched deano? How would that affect your revs staying high (I ask because i have the same problem - stupid revs).
Discussion Starter · #12 ·
Deano says:
coolant temp sensor
Deano says:
sounds liek a sensor to check the temp of the coolant
Deano says:
how to that affect revs
I reject your reality and substitute my own says:
he's observant
it tells the engine management if the engine is warm
and will alter the fuel mix accordingly
like a choke
Deano says:
i see
Deano says:
so if i am acclerating hard
Deano says:
and i pull off accelrator
Deano says:
and my revs stay high
Deano says:
its because of thisd coolant temps ensor
yup
Best Auto Insurance | Auto Protection Today | FREE Trade-In Quote
Discussion Starter · #13 ·
basically, my idle is a bit weird, sometimes its at 1k, then it will jump after accelrator usage to idle at 1.25 or 1.5
and when i am accelrating, the revs dont drop down afterwards very quickly at all. so i fond i am using thebrakes a lot more to scrub off speed.
i asked chris, he says teh coolant temp sensor is buggered.
Does the 'F have a mass air flow sensor as on my old Fiesta Si (ducks for cover) this was displaying exactly what you said.
In fact - stupid me I know it doesn't as I've changed the airbox on mine!
As above then, probably TPS I'd say ;o)
Discussion Starter · #18 ·
this is my list of symptoms...
when accelerating, the rev needle doesnt move smoothly, it jiggers a bit.
take foot off accelerator and the revs dont die, and sometimes it can feel like it is trying to carry on accelerating.
at idle, sometimes the stays around 1k, other times it rises to 1.25k
first thing, gonna clean teh contacts that sharky said, check teh 820 airbox over, and also see if the TB is dirty or not, will probably give the accelerator cable a once over as well and take it from there.
Might be silly, mine was doing similar but more eratic, and sometimes even cutting out, but the pump pedal 5 times reset thingy worked for me, you tried that?
1 - 20 of 22 Posts
