Where to fit turbo guage pipe?
984 views 4 replies 3 participants last post by  boothy90
I've now got a guage to fit to my chipped & boosted 25 TD 101.
Where is the best (easiest?) place to break into the air flow to fit the T-piece?
I've seen the MAP sensor mentioned - but don't understand / can't locate the right place.
i dont know the mgr diesel at all but I would imagine that the map sensor is wired to the ecu rather than a pressure pipe to a map sensor within the ecu, I dont know though. Easiest way is to use a rubber hose boost tap as close as possible to your inlet manifold.
http://www.revotec.com/catalogue_SelfSeal.asp
hth
