in every install i have done, i drill a hole in the spare wheel well (check for fuel lines first!), get rid of all the paint around the hole, have a good old dig at the metal with a screwdriver to ensure a good bit of raw metal and then connect the earth using a nut and bolt. you need an extra pair of hands to tighten up (unless you have really long arms!), but i have never had any problems with earth connections, alternator whine or anything using this method. if you are worried about corrosion, just slap a load of silicone over the bolt head once its all in place and you'll be fine.
don't forget to keep your earth wire as short as possible, preferably less than 1m in length and it should be
at least the same gauge as your power wire...
