1 - 5 of 5 Posts
i have just changed the thernostat and metal pipe that runs from it but now found water coming out of a funny shaped box under the metal pipe, this connect with an o ring also and has a pipe running off it. Should i replace this o ring also? I just need to know what its called so i can ask for the correct part at local (ex) dealers
Hi mate that box that your on about is just a oil breather bolted on top of the metal pipe with an o-ring in the back of the engine it sounds like the metal pipe is still leaking.I had loads of problems trying to stop that from leaking even after replacing the pipe and the thermostat housing,for some reason they dont like sealing on the o-rings at each end i used k-seal in the end but im not sure of the effects it will have on your car.
1 - 5 of 5 Posts
