I have had this before, but it’s an easy one to fix.MOT day, another year another pass.
Did get an advisory though on the wheel arch liner catching the wheel when on full lock
How did you get on?It’s MOT day today so fingers crossed, car is washed and waxed as I always like to present a clean car for inspection.
She is first in at 8am so should be done and dusted by 9 🤞🤞🤞
Hi Ian, Sod’s law the car had a flat battery!How did you get on?
I appreciate that is a pain, but the fact it started and ran after a major engine rebuild should be hugely encouraging to you matey - good work!Finally had some time to do some work on my 2006 TF (bought with engine dismantled) got everything back together on the engine, filled with water and it begun draining out....looks like either the metal engine coolant pipes or thermostat housing may be the culprit. Anyway, with the coolant filled turned engine over, fired once then died, used some easy start and it fired up but again died, checked for fuel, looks like fuel pump may be dead!......back to drawing board, will check fuel pump when my brother brings his pipe release pliers over, I have a spare so if its dead not really an issue....pipes are a pain though![]()
Oddly, as I sat about the garage while the guy did the car, I read a magazine called Classic cars, and they had an article about just that, sound proofing with a stick-on 3 layer plastic. Is it expensive to do, and does it work in cutting out all that noise mate?I agree makes a big difference to the car, pricey
Though , the cost of the bilstein kit has doubled in 10 years , next thing you could do to make the car even more plusher is to line the door panels, rear wings
Floor and boot with sound
Deadening self adhesive
Film , makes a huge difference
I just replaced my engine mounts in polybush as the originals had a bit of play
Big mistake! The car now feels like an old fordson tractor, steering wheel
Shaking on tickover
I have managed to get
Some new original rubber
Mounts so thats my job
Saturday morning
