I need to change my handles. Did you add remote locking/unlocking? If not how do I stand with the MOT if I can't unlock the passenger door from outside?Had the amber engine malfunction light illuminate yesterday, so Today I took her down to my local Rover specialist in Wrexham (R & J Motors). They very kindly hooked up their OBD reader (free of charge) and there were about half a dozen faults including short on fuel pump. misfire, catalytic converter and a few others. We (or rather he did) cleared them and touch wood, the light has stayed off thus far. I have a feeling that my rattling cat might have been the culprit - need to get that changed anyway soon.
Other than that, I finished off my project to 'colour code' my 1.6 mpi - had already changed the side air scoops, recently managed to upgrade from manual black plastic mirrors to colour coded electric ones and finally changed the door handles this morning so that they are all Tahiti Blue JRJ.
All in all, pleased with Today - next thing on the agenda is to fit the Mike Satur Mk1 chrome roll hoops that I acquired recently. A job for a nice dry day no doubt! - then it'll be on with my colour coded hard top for the winter.....god it's getting cold already!
I already had remote central locking so for me it was just a case of swap out the plastics and replace the original door locking barrels into the new handles - not sure how you would go about adding central locking if you didn't have it. I'm not sure if it would be a fail if you couldn't undo from the outside but curiously the passenger handle that I originally had did have a keyhole but the colour coded replacement I bought did not. I still placed the original barrel into the space simply for central locking purposes, but there is no way to undo it with a key unless one drilled through the plastic blank. In which case, I guess you could say that I couldn't undo my passenger door if my central locking failed.........I need to change my handles. Did you add remote locking/unlocking? If not how do I stand with the MOT if I can't unlock the passenger door from outside?
When I get back to the uk this is on the to do list.
Can you tell me how the sensor on the bottom of the res disconnects . Do I pull the sensor connector down. Or pull it to the side.Decided to replace my coolant tank with a much nicer, much cleaner one that I sourced from one of my local scrapyards. Easy job, took about 15 minutes to 'turkey baster' out the current tank, disconnect, fit new tank, reconnect and refill. Much better.
My tank doesn't have the sensor fitted, unlike later models. I think if you have the correct tank (part number PCF000140 with the additional sensor plug hole in the bottom) if you remove the old tank it should pull straight down off the bottom of the tank and should be push fitted back to the new tank. I found this guide about fitting a low level coolant sensor and the guide seems to indicate that fitting of the sensor is simply a push fit, so disassembly should be the reverse of assembly.Can you tell me how the sensor on the bottom of the res disconnects . Do I pull the sensor connector down. Or pull it to the side.
Filthy old Expansion Bottles can be cleaned up like new. I shake a few drops of petrol around inside the very dirty ones, then follow up with cloths tied to rods or stout wire to fully remove old coolant stains and residue. Then fully submerge and soak overnight in a weak Bleach solution.My tank doesn't have the sensor fitted, unlike later models. I think if you have the correct tank (part number PCF000140 with the additional sensor plug hole in the bottom) if you remove the old tank it should pull straight down off the bottom of the tank and should be push fitted back to the new tank. I found this guide about fitting a low level coolant sensor and the guide seems to indicate that fitting of the sensor is simply a push fit, so disassembly should be the reverse of assembly.
MGF/TF coolant level sensor
Is there any other option?All with top down
Out of interest, how will the new wiper stalk solve the lack of washer liquid being expelled?2. Windcsreen washer provides insufficent washer liquid front [8.2.3]
Ordered a ball joint and wiper stalk...
Advisory "014 (wiper stalk floppy but still works okay)"...but intermittently squirts, still replacement was less than £10 deliveredOut of interest, how will the new wiper stalk solve the lack of washer liquid being expelled?
Unless of course there is no water at all and you have found the stalk/switch to be the fault...
Superior German engineering. Deutschland über allesToday: Took our 2004 128,000 miles Smart Roadster to be MOT'd, passed! No advisories, cross examined the examiner... he could find nothing wrong with it...
