Hi all basically i would just like to know the rounabouts weight of a sohc rover 216 gti gearbox and if it would be possible to change the clutch on my own ?im confident about the job but not sure of the struggle to get the box on and off any info appreciated.
a t series pg1 is 30 kilos so it wont be heavier than that, should be able to mange ot your self using a trolley jack or similar.
I'd say 30-35 kg approx. I've taken the box out of a 216 gti tc 3 times. The main problem is getting the box lined up in the correct orientation when refitting. My neighbours must have learned a few swear words.
It would be much easier to fit with someone to lift it and someone else to rotate it into position. It doesn't sit on a jack very well.
The last time I hired an engine crane which helped a lot.
