How do I tell if it's a mk1, mk2, mk3...... Etc?
My ZS is a 2002 (52 plate). I've seen some that are on a 02 plate. Same goes for 03 and 53. I pulled the door card out of a 02 ZS 180 today. They fit in mine perfect except the plug for the electric window switch didn't match. But both are 2002 models? Is one a mk1 and the other a mk2?
Also I needed an exhaust manifold heat shield. I found one and I believe it was a k-series engine since it was a 03 ZS but the alternator was towards the bottom of the block not by the cylinder head like mine is.
Some of the front ends for example are different. One has a plastic bar type thing that goes horizontally through the grill but the grill is attached to the bonnet. Another one had the same grill but wasn't attached to the bonnet. Are both of these "facelift" models? If so, why the change?
