Ok, Not sure if this means anything BUT
I took the scuttle apart today (What a chore!) and found that there was some sort of sponge seal that goes along the bottom of the windscreen. In part, this was missing under the scuttle / windscreen (more on passanger side). I poured water down the windscreen with the scuttle lifted and noted that water dribbled down in to the air intake... (in to a square hole and what looked to be the motor blades???)
Do we think this is where the leak is???
Also today the heater motor began screaming at every speed. Then the motor struggled to keep its speed then at that moment I lost speed one and two on the dial...... It seems that the motor cooked itslef and then the resistor pack (both now ordered to be repalced.!)
- Did the water cause the heater motor to burn out do we think?
- Have I found the leak do we think?
- Whats the cure? (Silicone under the scuttle??)
Any advice peeps would be great
John
