With the current heavy rain water is collecting under the gap between the bonnet and windscreen of my Rover 75. It drains OK on the off-side but is collecting on the near-side and then overflows into the passengers foot well. I cna't find any reference to the location of any drain hole. Is it via the female hollow rubber bung or what? I suspect it is blocked with leaves.
Any help gratefully recieved!
Yhanks
from what i have seen, lift the bonnet and near the passenger side of the windscreen there is a drain hole, poke something into it to clear it out.
Banned
You need to act rapidly before your car ECU (computer) drowns in this water-the bills can be big!
Follow the instructions from the link below and pay particular attention to the centre drain point as that is the one that is both hardest to get to and most important. Despite what the sheet says this applies to all 75/ZT's built.
hth
Mike :)
http://www.75andztclub.com/datasheets/tid002.pdf
http://www.75andztclub.com/datasheets/tid001.pdf
more info also here http://forums.mg-rover.org/showthread.php?t=99817
