The manifold gasket could be the problem. You need to get a pressure test done asap. Don't risk doing these 200 mile trips until you have got it fixed.
Edd
Edd
Is that the inlet manifold? Screwed if I can't use the car, leaving shortly for Sheffield, 240 miles away! Cheers, Paul.The manifold gasket could be the problem. You need to get a pressure test done asap. Don't risk doing these 200 mile trips until you have got it fixed.
Edd
Thanks for the advice guys. Just had a new water pump 2 months back so I'm pretty sure it's not that. I read somewhere about the S/S Ts but a search didn't get me anywhere. Am I right in thinking someone on here makes them to order, if so can you give me a link or a name? It's absolutely persisting down here at the moment so very little chance of spotting the leak, although I have given the whole engine a good look over on 3 or 4 occasions since I first noticed the problem and can't see any tell-tales, I'll keep looking! Cheers again, Paul
