Everytime it rains, which is most of the time in the UK :lol:, I have a small pool of water on the rear passenger rubber door seals.
The bit that seals the carpet to the body. I have checked the rubber seals on the door and they are fine. Also I have took the seal totally off and put it back on again, but it still leaks :irked:
Anyone any ideas?
sunroof drainage hose?????
my 25 did this......a puddle in the rear drivers side footwell. was found that the sunroof drainage hose was not fitted correctly.
Naaah. Definately not that. It hasn't got a sunroof.
Hi my25 has same problem, the plastic membrane behind the door card seperates allowing water that gets into the door past the weather seals [glass] instead of draining through drain holes in bottom of door,some how manages to get onto plastic membrane and then onto door card and out into car, reseal membrane to door.
