Silicon will work, but replacing the gasket is a better and even simpler option though IMO.
I was just going to say check the foam gasket. And while its off waxoil/pain the bottom to stop rust.Silicon will work, but replacing the gasket is a better and even simpler option though IMO.
Its just under, there is a weld seam, and i saw an F eat its self from the inside out with rust from there. So i did mine with hammerite a good thick line down the weld and seams.OK thanks for that, I will nip down to my local dealer and get a new gasket.
I had the car waxoyled a few weeks ago, not sure they did round the rear light though!
Steve
I lifted the carpet and had a good look around and there is no sign of damp or rust beloow thie light. I has only started in the last couple of weeks so am assuming it is coming in through the light gasket. Also had a a poke around and pushed various points on the light and water trickled down on the outside (like squeezing a sponge). I will replace the foam gasket and have a good check round all the seams.Its just under, there is a weld seam, and i saw an F eat its self from the inside out with rust from there. So i did mine with hammerite a good thick line down the weld and seams.
