1 - 9 of 9 Posts
Hi there,
I was just wondering how you can remove the vis balance motor on the side of the inlet manifold. It is the one where the brake fluid resoviour is ? You have trouble getting to all the screws. What is the solution ?
thanks Ryan.
Struggle, it can be done by flexing the master cylinder and using a baby screwdriver although not to be recommended. Easier to remove the top half of the manifold.
mg_zs
And before you put the screws back, silver solder a nut over the head of each one. You can use a spanner then WITH CARE!!!
Doing this job on Friday,
Bought the MKE100102 motor is this the one obstructed by the resovoir?
any other tips on removal and refitting?
Ricko ZS180
will be doing the job next couple of weeks.
off to the Nurburgring on sunday.
the power seems to smoth since replacing the induction and exhaust, so changing the motors is for piece of mind, they may be actually working!
will send the motors, send me an address.
regards
1 - 9 of 9 Posts
