1 - 9 of 9 Posts
Discussion Starter #5
Unlocked means plug and all works I guess?
How much for posting it into Slovenia - Eirope :)
What car do you have? Do you have paypal? I would rather sell it to someone who can drive their car to my home, so we can unplug 5AS module, unplug original matched ECU , then plug in my unlocked ECU. If you are still interested. DM your address , I will get a quote from my local post office regarding the postal cost to you.
My knowledge is not the best,...
My car is Lotus Elise S1
It has MEMS 1.9 ECU (MKC104112) and Lucas 5AS module, no additional alarm.
To plug, I must first disable the 5AS immobilizer pressing button on key fob, disconnect 5AS module and then ECU?
Replacing ECU and then plug back 5AS module?
After that I don’t need more key fob for starting?
It all works also if I disconnect the battery?
thank you
I have paypal.
Discussion Starter #8
With the unlocked ECU, the 5AS box is not required, before plugging in the unlocked ECU, the 5AS box must be unplugged. Once the unlocked ECU is plugged in. Insert key into ignition barrel , turn key, starter motor will start engine.
1 - 9 of 9 Posts
