Clean oil is the lifeline of a turbocharger, regular changes will prolong the operational life of it.
Driving style will also have an effect. Allowing the engine to idle for a minute or so after a fast run will allow the turbo to cool down and prevent the oil from carbonising in the bearings due to the terrific heat build up in the turbo after engine shutdown.
There should be little or no dirt build-up on the turbine - if there is, then there is a serious air filtration fault >=( which isn't good news for any turbocharger
