21 - 40 of 74 Posts
Discussion Starter #25
Quick update, got the engine painted today so plan is to get the engine and box built back up and fitted tomorrow....
2018-03-31_09-07-32 by John Quincey, on Flickr
Then onto the wiring.....
2018-03-31_09-07-48 by John Quincey, on Flickr
This is only about 3/4 stuff will need not all has turned up yet but this is enough to get the engine to the bulk head done. Im using Deutsch DT series motorsport multi plugs to on the engine side of the loom to the car side so should the engine need to come out is just a case of disconnecting 2 plug and can lift it out with all wiring etc on it. I also got the factory terminals for the engine bay fuse box so can use the original multi plugs that plug into the bottom so theres no bodging needed i will just use the original plugs with new wires and terminals so my ECU can power the fuel pump, main relay etc etc
Discussion Starter #28
Well unfortunately weather didnt play ball this weekend but got a fair bit done on Saturday so fingers crossed should be at POL. Anyway while the weather was bad today i got the loom made that will link the engine to the engine bay fuse box and into the car. Just need to test fit it to make sure everything is the right length and i havent missed anything before covering it with flame and fluid resistant heat shrink....
2018-04-08_09-57-23 by John Quincey, on Flickr
Discussion Starter #29
Just a quick one to keep thread going. Unfortunately due to work and kids party's at weekends still running behind but not far off now just the final bits of wiring, coolant pluming and exhaust to sort and should be there i think.
Another few of wiring, hoping to have it finished this week still waiting on the Deutsch crimpers to come so can get the multi plugs on....
IMG_20180420_001624~2 by John Quincey, on Flickr
IMG_20180420_194500~2 by John Quincey, on Flickr
Few of the car finally got the bumper top coated and the panels back on....
IMG_20180422_202929~2 by John Quincey, on Flickr
IMG_20180422_202945~2 by John Quincey, on Flickr
IMG_20180422_203537~3 by John Quincey, on FlickrIMG_20180422_203549~2 by John Quincey, on Flickr
Ive also booked the car in my local car show "the haynes 100" (idea is to have a car from each year covering 100 years) in June to cover 1993
Agh this is reigniting my desire to buy an old shed and go racing. The good lady in my life wouldn't like it though.
Can't wait to see this finished, hopefully when you get it on track you can get a few vids on YouTube too.
Discussion Starter #31
I must say missis is ok as long as bills are paid :rocker: yes be back on track soon not far off done now with my trusty GoPro :unionflag:
Discussion Starter #32
Well started what i thought was going to be a easy job today. Thought i would get the Coupe bonnet flatted and grill holes sorted ready to get painted next week so flatted the top coat down....
2018-05-06_09-39-38 by John Quincey, on Flickr
But once i took off the top coats found a few touch up and poor repairs.....
2018-05-06_09-39-55 by John Quincey, on Flickr
So had to take those spots back to bear metal and add a skim of filler....
2018-05-06_09-41-22 by John Quincey, on Flickr
2018-05-06_09-41-46 by John Quincey, on Flickr
Then flatted again followed by a coat of high build primer...
2018-05-06_09-42-06 by John Quincey, on Flickr
Then the joys of a wet flat of first 1200 followed by another wet flat of 2000 to get it nice and smooth.....
2018-05-06_09-42-29 by John Quincey, on Flickr
So after best part of the day its really for the body shop but bearing in mind its only getting used on track and will most likely be stoned chipped first time probably been a waste of time
Discussion Starter #33
Bit more done today just getting wiring finished hoping to get the ignition on tomorrow at last....
First off adding the Solder sleeve's onto the shielded cables to allow any noise to travel to earth for the Lambda and crank sensor signals. I dont run a cam sensor on mine engine so only 2 needed....
IMG_20180510_205342 by John Quincey, on Flickr
Few of the plugs and terminals using gold plated terminals for all sensor signals and standard for power and grounds....
IMG_20180509_211736 by John Quincey, on Flickr
Adding in the splices for common power and grounds and covered with Motorsport Raychem spec ES2 end caps.....
IMG_20180509_211716 by John Quincey, on Flickr
For the join between the engine bay and inside ive used Motorsport spec Deutsch DT Series plugs so should the engine need to come out i just need to disconnect the plugs and all wiring from the engine and engine bay fuse box etc will come all together nice and easy with the engine with all sensor signals on 1 plug, powers and ground on the other 24 pins in total. The plugs are mated male to female, female to mate so i cant mis-match them and blow the ecu.....
IMG_20180510_183717~2 by John Quincey, on Flickr
And finally i stripped, cleaned, rebuilt and sprayed the Alternator as everything else has been done....
IMG_20180509_211924 by John Quincey, on Flickr
Discussion Starter #34
Little update, ive changed the Lotus Cam Cover to a Rover unit and was a bit bored today so made a little YouTube video. I also wired in the ABS warning light in as a shift light which comes on at 6500 rpm on the "road map" and 7300 rpm on "track map"....
John,
Let us know where you are on track next, as I am sure there are several of us that would like to view how the car performs; good or bad!
21 - 40 of 74 Posts
