1 - 20 of 74 Posts
Just to let everyone knows whats going on im replacing the ZR that i was building to hopefully have a bit of fun doing some motorsport with with this BEAST from Rover :lol:
WP_20170805_19_53_00_Pro by John Quincey, on Flickr
WP_20170805_19_53_26_Pro by John Quincey, on Flickr
WP_20170805_19_44_29_Pro by John Quincey, on Flickr
WP_20170805_19_56_51_Pro by John Quincey, on Flickr
WP_20170805_19_43_19_Pro by John Quincey, on Flickr
WP_20170805_19_43_31_Pro__highres by John Quincey, on Flickr
WP_20170805_19_43_52_Pro by John Quincey, on Flickr
WP_20170805_19_42_57_Pro by John Quincey, on Flickr
WP_20170805_19_54_05_Pro by John Quincey, on Flickr
WP_20170805_21_01_27_Pro by John Quincey, on Flickr
Doesnt look like much at the minute but over time the plan is basically have something looking much the same as a 216 GTI Dunlop Cup Car but i will be using the engine from the ZR. As the weather has been rubbish all week not got anything done other than remove the engine etc from the ZR.....
WP_20170806_18_17_03_Pro__highres by John Quincey, on Flickr
WP_20170806_19_04_35_Pro by John Quincey, on Flickr
WP_20170806_19_04_47_Pro__highres by John Quincey, on Flickr
The car is a K Reg 214 Sprint, base model, non sun roof, one owner from new with loads of history (not that it matters) and has been garaged still 2013 due to illness and passing of its owner. As you can see he done a great job looking after it as its completely rust free so a great base to start the project off with
A good motor with which to start your project, but won't the body be heavier than the ZR?
Once you finish & get it on track, what class would you be racing in?
If the weights from the Dunlop series are correct it will be slightly lighter (ZR was 1060kg with me and 1/4 tank fuel) plan is to be in 750's hot hatch challenge but as the Rover is pre 95 in opens up a few more series now
Discussion Starter #9
Got a bit of time on the car today at last, got the inside stripped with a bit of help from my boy (he has taken a shine to the R8, says when hes finished his Go Karts will race the Rover) and all the sound deadening etc out was way more than in the ZR.....
WP_20170812_12_12_39_Pro by John Quincey, on Flickr
WP_20170812_19_57_00_Pro by John Quincey, on Flickr
WP_20170812_20_58_13_Pro by John Quincey, on Flickr
WP_20170813_11_52_14_Pro by John Quincey, on Flickr
WP_20170813_11_52_37_Pro by John Quincey, on Flickr
Also started having a mark-up of where everything will go etc so can get the floor bars welded in ready for seats, get the wiring loom made, battery mounted etc etc....
WP_20170813_11_52_57_Pro by John Quincey, on Flickr
And found a original GTI challenge sticker on Ebay.....
InstagramCapture_4e7adad9-5958-4322-9c64-63032fcc526a by John Quincey, on Flickr
Discussion Starter #10
Finally got bit done to the 214 today been so busy lately. Anyway got the car to work so i could remove the drive train and start mocking up for the new engine/wiring and will be painting the engine bay/front panel white before the 1800 goes in.
Up on the ramp....
WP_20170930_09_51_36_Pro by John Quincey, on Flickr
Making a start....
WP_20170930_12_24_33_Pro by John Quincey, on Flickr
All disconnected....
WP_20170930_12_24_44_Pro by John Quincey, on Flickr
On the deck....
WP_20170930_12_35_47_Pro by John Quincey, on Flickr
WP_20170930_13_33_32_Pro by John Quincey, on Flickr
And in the boot....
WP_20170930_15_24_14_Pro by John Quincey, on Flickr
Discussion Starter #11
Forgot to say yesterday I weighed the 214 on the ATL yesterday (same lane as ZR) with 1/4 tank, me, 17" wheels, 2x factory seats and OE battery and it was 1032 KG. The ZR as it stood with 1/4 tank, me and one race seat and motorsport battery was 1070 KG so good news is the Rover should be about 50 KG lighter which is great news!
Discussion Starter #12
Small up date everyone picked up some replace rear trailing arms and a ZS roll bar so can put on the rear discs off the ZR160, get them painted and poly bushed....
WP_20171014_18_03_46_Pro by John Quincey, on Flickr
Also finally got the steering column panel from a scrap ZR so i can drill out the spot welds and fit the mounting bracket to the R8 so can use the ZR steering rack and front sub frames....
WP_20171018_19_46_59_Pro by John Quincey, on Flickr
Hopefully can get it on this weekend so can get the engine bay painted and engine in next month..... fingers crossed
Discussion Starter #13
Keep forgetting to update thread here, not done much because of weather but i have been getting parts etc....
3x different bumper....
WP_20171119_11_45_12_Pro by John Quincey, on Flickr
WP_20171119_16_28_53_Pro by John Quincey, on Flickr
WP_20170906_19_38_22_Pro by John Quincey, on Flickr
Managed to get some hard to find parts, set of sill extensions and a GTI spoiler....
WP_20171130_18_06_47_Pro by John Quincey, on Flickr
WP_20171130_18_17_25_Pro by John Quincey, on Flickr
Get some adjustable camber arms but can only get 1-1.3 degrees so not much use to me got another set on way....
IMG_20180122_201135~2 by John Quincey, on Flickr
IMG_20180122_200319~2 by John Quincey, on Flickr
Made a panel from fibreglass resin to allow the ZR front subframe/steering rack to be used on the R8, just needs smoothing ready for paint....
IMG_20180113_201419~2 by John Quincey, on Flickr
And gave it a wash :wink:
WP_20171214_12_33_47_Pro by John Quincey, on Flickr
Still no end to do but least things moving
Discussion Starter #16
Got the other camber arms today and glad to say they will work perfect got plenty of room for adjustment from standard to around -3 degrees (could go more with coilovers i think as trailing arm hits the lower shock body) So thats one job sorted on to the next hundreds
IMG_20180125_190402~2 by John Quincey, on Flickr
IMG_20180125_182622~2 by John Quincey, on Flickr
IMG_20180125_182807~2 by John Quincey, on Flickr
IMG_20180125_182739 by John Quincey, on Flickr
IMG_20180125_182837~2 by John Quincey, on Flickr
IMG_20180125_182713~2 by John Quincey, on Flickr
Discussion Starter #19
Little update, trying my best to get ready for POL in some form anyway. Got the engine bay just about stripped ready to get it painted hopefully can get done next weekend.....
IMG_20180311_162853 by John Quincey, on Flickr
IMG_20180311_162913 by John Quincey, on Flickr
Just need to finish sanding the panel for the ZR subframe rack to smooth it off, bearing in mind made it from starch came out ok.....
IMG_20180311_164210 by John Quincey, on Flickr
And finally got engine and gearbox on stands ready to paint before fitment.....
2018-03-11_06-01-25 by John Quincey, on Flickr
1 - 20 of 74 Posts
