Does anybody know how to turn off the TPMS sensor light?
All the tyres have enough pressure but it is giving a false reading for one of them. Is there a way to reset it?
You cannot reset it, if all the tyre pressures are ok it will reset itself after a short period of time. Check the tyre pressures via the menus, make sure they are all the same. My dealer says run them at 2.1 bar as anything less makes them likely to bring up the TPMS alarm, particularly in cold weather. This certainly works for me.
Hope this helps...Chris.
The Tpms does have a known fault.
Indeed mine is with MG at the moment to get the fault sorted. Funnily enough it swapped placed with another ZS that was just coming out for the same issue!
