Towing with a Rover 25 1.4
5.3K views 11 replies 5 participants last post by  ashy
Has anyone towed with a 1.4 25 please?
If so does it do ok, i think that it is meant to tow up to 1000 kg just a bit concerned that it will be a struggle.
Any help with this would be great.
Allan
It depends on what you are towing. There are a number of factors to consider:
  • Towing capacity of vehicle (in this case 1000Kg)
  • Weight of the towing vehicle
  • Weight of the trailer
  • Noseweight on the towbar
General advice is that you shouldn't tow more than 85% of the weight of your own vehicle anyway, regardless of towing capacity. However, without doing the numbers, I'd say you'd be OK with a trailer tent of say, 500Kg, although it might struggle a bit. I wouldn't tow a caravan at all with it. I towed a caravan with a 1.6 Carina E - barely adequate would be the phrase I'd use.
