I changed timing belt and water pump changed yesterday and now there is a whirring noise low down in the rev range.
It running ok without any other problems. Timing is all ok but I just wondered if this is normal? Has it got to settile in over so long and then the noise will disappear?
It running ok without any other problems. Timing is all ok but I just wondered if this is normal? Has it got to settile in over so long and then the noise will dissapear?
You may have overtensioned the timing belt.
