other_rover
....is the access to check the bushes that usually cause the problems done from above or below?
I have a few days of work and plan to sort the problem.
mg_zt_t
... and most of the time it will be very worn hinge pins in the u-j on the end of the gear lever selector shaft at the gearbox end. This is what can happen when allowed to wear excessively thus needing much side leverage to select 1-2-5-Reverse ~ it will sheer off eventually:
