This is our MG TF we bought new in 2004, it’s the cheap 115 MF TF version with a 1600cc engine, it served us well over the years,
Yes we had HGF after only 6 years of ownership with 38K ~ 39K miles on the clock, apart from that it was a pretty reliable car
In 2014 the engine let go for the second time, we were driving home one afternoon and all of a sudden with a big BANG it lost all power,
When I cranked the engine all I could hear from the engine was what sounded like grinding metal and not turn over, I stopped attempting to start the car immediately and called up Green Flag to take us and the car home
When home I called out our regular guy who used to service the MG TF for us, he thought either something with the pistons had given up or (unlikely) the belt had slipped causing the valves to hit the piston heads
Either way it was going to cost us far more to fix the car then the car was worth, so we parked it on our driveway and there it’s stood since 2014, over time I’ve taking off the odd part to use on my Elise
Now I’m in the process of having a double garage built I’ve turned my attention to striping our MG TF down in to spare parts and help keep other MGF/TF’s on the road
I know if I called out the salvage people to take it away for me, they would just end up piling other cars on top of it without much parts taken off, ending up all being crushed
I’ve seen this before when going to local scrap yards in the passed, if parts aren’t taken off cars soon enough the whole car gets crushed,
Till my garage is up I don’t know when I’ll be making a start, but fingers crossed sometime in early 2022
I’ve never stripped an MGF/TF before so this should be some fun, I did once strip a Rover 100 to build a kit car but that was 21 years ago
Starlight Silver MG TF 135
This looks to me like a GOLDEN opportunity for someone who needs MGF parts and/or has room to store them, to help you strip the car and buy the bits they want. May I suggest that you indicate what part of the country you live in, then anyone in your area (or prepared to travel to your parish) can then message you and you can discuss terms of engagement etc.?
Good Luck whatever you decide.
JohnE
Be a shame to strip it but if you've already started removing parts it would probably cos tto much to recommission, One thing, if it still has the original cat it will be worth a few hundred so you can make some pennies on that alone.
Looking back at your original (2004?) posts, you appear to be the original owner of this poor, dilapidated TF. If you ARE the only owner, that in itself adds value if someone is prepared to put in all the work needed to restore it. If you have all, or even most of the old MOTs and other documents to verify the recorded mileage, that would be another value-adder. All that is not much good if the subframes and sills are rusted beyond repair. It looks like water has been able to get into the interior, so presumably the carpets have been soaked, so are the floors rusted?? The only other ray of hope I can offer is that at least 1 person has already has already done an electric motor conversion of an MGF search
Electric MGF/TF
to see more.
Stripping the car is one option, but when you have put all the effort into stripping it into individual parts, it will then occupy about three times the amount of space that it did, and probably take you three times as long a you thought it would. Then you have to accommodate the numerous callers/interested parties who might want to buy bits A, B and C. Then after x months of nothing happening, you have to take the remaining bits to the tip, or see if a scrappy will pick them up.
To me, it’s a non brainier to simply sell it as complete.
