This is a problem that has been with us since we bought this 98 MGF a few years ago.
When we bought it and brought it home on a trailer it was plonked on the drive and I got to work sorting all the things that you normally sort as soon as you buy a car but the engine just wouldn't come to life at all......until, whilst kneeling down to mend the heater valve cable that was hanging down by the clutch pedal, I spotted a small rocker switch. I flicked that switch and it started with the first turn of the key.
A crafty immobiliser I thought and phoned the previous owner to thank him for not telling us about it. He told me that he had taken the car to an auto electrician to solve this battery drain problem and the electrician had added the switch to the board under the steering column because a relay was not shutting down properly after the ignition had been turned off.
I've been looking about the web on this and apparently it can be down to the ECM not shutting down and the check was to find the pink/brown wire going into the ECM should be checked 20mins after the engine shut down to make sure it wasn't still live. I've done that check and it does shut down.
Now, We do have a "parts" car that is working with none of these faults. Can I swap the board under the right side dash without any problems, or is there some other parts that I'll need to bring with it?
Many thanks in advance! S
