The top ball joints need replacing on rear and one on front, decided to start on the rear. The workshop manual suggests taking the bottom bolt that holds the shock to the upper arm presumably to allow a bit more movement to allow the oversized 46mm socket to fit – but no, the arm and shock over the last 20 years appear to have become welded together and I can’t sperate the two. In any case the shock bush doesn’t look to in great shape. So decided to remove the long bolt holding the bolt in place only to find it fowls on the rear ARB. Can’t quite get to one of the the nuts holding the ARB to the car as the heat shield is in the way looked to drop the heat shield down slightly only to find the bolts holding it to the car are now rusty blobs…
