Hi all!
I'm currently working on my 2004 135. Previous owners have done a number on the loom specifically around the dash to install various bits. So much so that it was basically a fire hazard and fault finding was near impossible.
So...
I have bought a loom from mgfandtfbitz and I'm pretty happy with it. Only some minor blemishes easily tidied.
I have spent a few days stripping down the old and installing the replacement.
*minor difference I found was the replacement did NOT have wiring for the exhaust volume sensor. Not fussed it's disconnected anyways.
Since install the car runs drives and works, except:
Engine bay fan runs constantly rather than when gets hot. I obviously don't want to deal with a burnt out fan or any other problems so looking to correct it.
First check was at the bay sensor which the new loom has the wires/plug for but I see that the replacement loom has a black wire and a black/green wire. First sign of alarm as they are different to the original. I've since been through a lot of testing/comparison to the original and I'm drawing blanks.
I've replaced the sensor. (Incidentally, just thought are there variations on these? That said they should still work in cool startups)
-Closing the loop bridging sensor doesnt turn off fan.
-Sensor checked for ohmage and looks to be good (old sensor and new)
-black lead solid earth to chassis
-green/black lead reads about 10.5v with battery on, solid connection to ecu.
-ECU worked fine when originally disconnected. (This is a KMAPS modded which again, worked fine days before)
-only difference in loom is it's missing the evc valve connection which isn't part of the situation.
-all bonnet and cabin fuses and relays good.
Anything I've missed? Will all sensors wires still be in the same ports on ecu? Anything else that will trigger the fan? (I've not touched the engine loom but that may be next on the list.
Help! Please!
So...
Help! Please!
