TF carpets V MGF carpets
4.9K views 14 replies 9 participants last post by  mowog73
Hi
Does anyone know if the TF carpets are a better fit in a "F" than the standard "F" carpets?
I have just ordered a new set of TF carpets and hope they are slightly bigger as mine in the "F" pulls away from the door edges.
Apparently they are a better fit. Instead of underlay like the F they have a foam backing.
This is something I will be doing, in fact I got some second-hand TF carpets off fleabay, unfortunately the morons folded them, twice, to send them and of course the foam backing is split.
My trophy had TF carpets fitted when I first got it, there was an issue on the drivers side just in front of the door, the carpet bulged around where the control box (I think for the wing mirrors). I ended up replacing it with a set of Newton Commercial carpet for a perfect fit.
A later TF carpet won't have the indentation for the electric window ecu that lives in the footwell as this function was built into the Pekteon scu when that was phased on (oval key fobs).
The TF carpet is also one piece where I believe the F one is two?
Newton carpets definitely fit better, at the end of the day you get what you pay for in this case :(
Just stripped out all the old carpets and trim from my 1999 F and replaced them with carpets door seals hood seals etc from a late 2005 TF.
Fit is a lot better it does mean center console to do the job properly but you could if you wanted I think cut the carpet in half down the middle to get it under the center console if you left that in.
Also as mentioned you do need to cut the foam backing away in the drivers foot well to allow the ECU to fit in.
Apart from that well pl;eased with it lifts the interior. And yes if you are a little clumsy with your feet the carpet will pull away from around the door. But its not a problem when you know its there.
#14 ·
Hi Kameleon,
I would give Martin Smith a call in Somerset on 07722 175473
www.usedmgtfspares.co.uk.
his advert is in most of the MG mags, MGE, Safety Fast etc. Great guy, great prices and very knowledgeable. Only sells top quality parts new and secondhand.
You could say my 1999 F has been rebuilt by Martin. Not only with the interior but TF wings, bonnet, but also a boot lid, Double S S/S exhaust, a new hood and of course the door cards, center console, carpets and seals all from a late model TF.
Hope that helps
Tone
