Temp gauge on my vvc 96 F not registering, was working fine yesterday but nowt today. When turning ignition on the needle seems to move backwards a fraction. I'm guessing it's the temp sensor anyone know where it's located & do I need to get the cover under the hood removed to find it?
thanks
Is this oil temparature or water?
If it is the oil then i can say mine stopped working about 2 days after i bought the car. I removed the centre console and found that the connections had worked loose.
I agree, most likely the sensor in which case I can`t help you but if its the gauge itself (unlikely) i have a spare one going at low low cost
Chris
It is the engine water temp gauge. I dont think it's the gauge it' self as I say it moves backwards a tad when turning ignition on, just need to find out where the sensor is?
