1 - 2 of 2 Posts
My friend needed to replace the clutch of his car, and that part was easily done, but now we have to reattach the gearbox. Our problem is that we cannot get the splines aligned. Any advice on how to do that?
Did you use a clutch alignment/centre tool?
If you did and everything is centralised, you may have to wiggle the back end of the gearbox around while pushing it forward. If the splines are a little out, you may have to rotate the gearbox slightly while you do all of this too...
1 - 2 of 2 Posts
