Car is a V reg Rover 200 1.6.
I am trying to diagnose this without actually ever having seen the car! The sister in laws car had HGF and a local garage did the job (not a cheapo quote either!). When she picked it up it was fine when cold, but started to tap when warm. I told her to take it back & they added some tappet fluid & told her to run it for a few weeks. She has done over 100miles over the 2 weeks & it is still there.
I did the other halfs MGF HGF about 12 months ago & had tappet noise when first starting after the repair as you would expect, but not anything after the first run or now when warm.
Sounds to me like a faulty or damaged lifter maybe? If it isnt filling up surely it should be noisy from cold?
Discussion Starter · #2 ·
Ohhhh shameless bump!
Anyone any ideas? Should the garage have spotted a faulty lifter or potentially damaged one?
They said as a gesture of goodwill they will only charge 1hr to do the job (they reckoned it would take 3-4) and only charge for the lifters that needed replacing.
Are we being taken for a ride???
mg_zr
No it doesn't sound like it. Some engines do make that noise, others don't.
It could be anything. Piston slap, tappets, injectors, charcoal cannister etc etc.
To be honest, if i do a short journey in my ZR, you can hear a tap tap tap when it's idling, and the temp needle shows optimum temp. After a longer, harder run, it quite quiet.
I always warm the car up by driving gently for around 2-3 miles, then once fully warmed up drive normally.
I'm almost certain it's nothing to do with the previous HGF.
Mmmm....Rover..
Did the oil and coolant mix when the HG failed?
A good flushing of the oil system and a fresh fill of good quality engine oil may well fix the problem.
