this is probabaly a really simple thing to do but i just cant manage it.
the button which pops up and down for the lock has fell of its arm so its constantly down(the locked position). all i need to do is get the door card off so i can latch it back on.
any help pls?
mg_zs
rermove window winder handel using a thin/strong wire hook to remove the clip that holds the handel on.
Remove scews holding armrest
Remove screw holding inside handel and slide handel forward. Using long nosed pliers unclip rod form latch.
Starting at bottom, unclip door card form door.
Lift upwards at front then along to disengage form door to window seal.
I think that is about it from memory.
it is best 2 do this with your window down and dont forget to remove your tweeter first
mark
