mgf
Hi!
Today I was with my MGF 1.8i 1999 (non VVC) at the yealy MOT controll (Sweden). The car did not pass the MOT :(
Following values:
HC:196 (100 max valid value)
CO:2,1 (0,5)
CO 2500: 5,6 (0,3 CO value at 2500 rpm)
Lambda:0,84(0,97-1,03)
Last year - ok MOT with values:
HC:0,99(100 max valid value)
CO:0 (0,5)
CO 2500: 0 (0,3 CO value at 2500 rpm)
Lambda:1,1 (0,97-1,03)
I think the lambda sensor is broken?
//Rodrigo
Before you go and get a lambda check the little black vaccum pipes that run from the ECU to the manifold etc... Meg had one with a tny hole and it screwed the emissions twice - I changed loads of stuff then found the hole and sealed it with 10p worth of shrink wrap and then she passed!
You have some great fixes Adam, did you watch Blue Peter much as a kid? :lol:
Glad your fixes are better than your speed of reply :)
  • Like
Reactions: Austin2297
