Hi
I swapped the rear window of my Mk2 roof, but the corners don't sit into the channel properly. I can get the three clips over around the base of the roof in the centre but I can't get it to latch down in the corners
Is there a trick to the order of the hood fabrics? Like, does the rubber piece go under the metal bar, or is it left loose? I have looked at the guides, but I am obviously still doing it wrong.
It should work. It may be stiff initially as a new window fabric - the corners where the window fabric meets the hood fabric is thick. When I fitted my new glass window, I had no problems at all. Have you ensured that the rivets are tight? The metal bar goes right up against the fabric (on the outside) and then rivetted. The rubber sits over the lip of the drain channel. You need to study some web photos to be sure that you are right.
