1 - 9 of 9 Posts
ive just finshed puting a 1800 into a rover 214 and got a new batery for it and the next mornin it was flat the alternater does work cuz it starts after i take it out can anyone help? thx also my petrol clock is not going up? anyone no why im new to rovers thx again:)
mg_zt_t
BATTERY DRAIN > Ist thing to check is Alternator output. With engine running, you should have 14.00 volts or a little more showing on a MultiMeter. A faulty alternator can drain a new battery overnight even if the engine is switched off!
How does the red 'battery' charge light appear - on all the time - not on or does it go off immediately engine is started?
The fuel gauge could be a simple loose connector ... after working on a car, it is easy to disturb a connector so that it does not work properly. Check all the sensors and connectors ( those on alternator too) particularly all those that were disturbed during 1800 transplant.
New to Rovers then just finished putting 1800 in ... that's what I call jumping into the deep end big time..... like your style ..;)
Get your Rover sorted and I believe you'll like it.
soted! the aa came out and used the amp thing it was the horn ? lol so toke the fuse out lol thx u all .....
mg_zt_t
Bit puzzled by that ... What? .... was the horn...
Rover_King said:
These Rover alternators dont seem all that good.
Nothing to do with Rover, they never made their own alternators anyhow. It's a wear and tear item which every car will need eventually, your Rolls Royce Phantom is just as likely to need a new alternator as a Rover 400.
1 - 9 of 9 Posts
