1 - 1 of 1 Posts
Mk2 200 - 1993
I need to replace the rear front suspension sub frame (if that makes sense! I.e. the one with the steering rack fitted through it).
Can it be changed with the engine in place? I hoping that *all* I need to do is remove the steering rack and disconnect all the suspension mounting points and it should drop down. With the exhaust down pipe disconnected from the manifold, hopefully it will just be able to slide out sideways?
Are there any flaws in my cunning plan? :D
1 - 1 of 1 Posts
