1 - 8 of 8 Posts
My F makes a strange whirring/chirping noise at 1500-1700 rpm. This only happens once the engine has warmed up, after 20 minutes or so. The noise seems to come from somewhere behind my right ear. I took it to the garage, but they "found nothing". I suspect they didn't run the engine for long enough to warm up. Has anyone experienced this? I don't think it's a big issue, but it's irritating. Thanks!
OK, that's anybodys guess - rev/resonant frequency and heat/expansion related. My first port of call would be the exhaust system & heat shield.
mgf
Bizzarly enough, I've had the same thing since I had the alternator belt changed. You only get a whiring noise as you pulling off. It seems to have died down a bit.... still get it slightly.... but it was very noticable after having it first changed.
I'm trying to remember if it quietened down after I had my HG repaired. Do they remove the alternator belt for HG repairs?
In the Garage
MG TF
It can be too tight with possible damage to the barring in the pullys or alternator, and it would be more likely to snap.
1 - 8 of 8 Posts
