Fitted a 52mm throttle body I am finding the TB is sticking open very slightly which means when I come off the gas the revs stay at a constant level (V v unnerving!). I have looked at the spring mechanism and the spring for the valve is on top of a white nylon runner/washer. I have greased/oiled this but it still sticks open and will not fully shut. If accelerator whacked open it whacks fully shut just not at slow on/offs on the pedal? I have checked the cable and it is ok just the TB??
mgf
Hmmm, Trophy (52mm) throttle body is pretty bomb proof and this is the first i've heard of one sticking.
I take it you have looked at the throttle cable and adjusted the tension to suit?
Other than this, the only possible thing i can think of is the retaining screws for the Throttle Position Sensor (TPS) on the rear of the throttle body, i know that if these are done up fully then they project out the back and can foul the spring (stopping it from closing fully). Worth a try anyway.
i took my throttle body of my rover before i installed it though i degreased it through and through making sure there was no dirt or oil anywhere then installed it today and it's so much better i now know that my plastic throttle body was sticking lol the alloy throttle body rules
