1 - 5 of 5 Posts
Does anyone have any tips about getting the engine turning over after replacing cylinderhead gasket and re-surfacing the head? Is there an immoboliser override?
cityrover
im assuming you are saying the engine will not start, which lights do you have on the dash when you turn the key all the way? any noises? explain further....
other_rover
crank the engien by hand first, make sure it physically turns wihtout valves hittin pistons. :) or pistons hitting the socket/rusty bore(cause it wasnt cleaned and oiled)/etc :)
Mmmm....Rover..
In my experience there is nothing special to be done...provided all the work has been done correctly.
The last two I did started up straight away........
1 - 5 of 5 Posts
