Hi does anyone know the rotational direction of the starter motor on a MGF 1.8 NON VVC the part number of the starter is NAD10050 it is 1.4kw 12v 10 tooth model. Thanks in anticipation.
Not off the top of my head, but you should be able to work backwards from the engine/flywheel rotation and how the starter engages with it.
On that basis, I would say it’s clockwise 🤷‍♂️
Hi, this is what I think because there is an arrow on the motor showing to my mind clockwise. Because when you think about it the starter ring turns anti, so in order for the starter cog to turn the engine it has to turn clockwise. Because as you look at the rear of the F engine the starter in mounted on the right. Correct? I only raised the question because one seller insists that the s/motor is turned anti. Thanks very much for your input. Regards.
