SRS light on
3K views 16 replies 10 participants last post by  Man in the Car
The SRS light has been lit since I got the car but I wasn't too worried as I assumed it would be the connection under one of the front seats.
I've just removed the standard seats and fitted some BRM ones but the SRS light is still on.
Is there a fuse or something else that might be keeping the light on?
Thanks in advance.
Would that not be an MOT failure? I'd rather not go down this route.
I've sprayed some wd40 under the seat plugs but its still lit.
I've noticed though that with the ignition on but engine not running the SRS light comes on and then disappears for a split second before coming back on again and staying on.
#14 ·
If you take the bulb out you WILL fail the mot. Its a testable item as is the ABS light.
All that the current MOT Testing Manual says about the SRS light is:
Check that the Supplementary Restraint System (SRS) malfunction indicator lamp (MIL) does not indicate a fault in the system
and the reason for an MOT test fail:
A Supplementary Restraint System (SRS) malfunction indicator lamp indicating a system malfunction.
It did originally state 'light inoperative' as a reason for failure, but the up to date version of the manual has had that wording deleted.
Therefore, SRS light inoperative does not, at present, appear to be a reason for rejection.
