1 - 13 of 13 Posts
Not really....but when you change the pads use the EBC Greenstuf ever since I fitted them mine dont squeak
You do have the AP big 304mm brakes right?
In the Garage
MG TF
The the pads can be removed and cleaned of dust and put back with copper slip on the non-friction side of the pads. This may help.
I'd agree with Chris :broon:
... 'and don't lubricate them '
... this phrase is sooo old, the beard has growed
up to 17 kms meanwhile ;) :getcoat:
Had mine cleaned up by techspeed a few weeks back...they still squeal.....its only when I first pull away tho, they don't do it once I hacve been going a while
mikef
Paul wouldnt have a clue (i dont think). he's got no interest in cars either
I don't mind having a look at your breaks for you one weekend, a bit of copper grease usually fixes the problem. I could get both of the front wheels done in about an hour if you supply the tea!
Peter
Sooo pleased i'm not the only one with squeaky brake syndrome... Tends to clear up once there is a bit of heat in them though.
Squeak til I get out of the village on the way to work, then magically clears up.
1 - 13 of 13 Posts
