1 - 9 of 9 Posts
hi guys, today i wheel spinned my 620ti in first gear and the front end bounced up and down a few times, and straight away the speedo stopped working
now and again it goes up and down as if there a connection but doesnt stay there for more than 1/2 a second.
has this happened to any one before?
is the speedo electric or cable driven?
is there just a connector that i just push back into place?
oh and ive recently had my clutch changed too
cheers
john
Hmm have you checked the diff bearings recently? The speedo packing up is often not a good sign for the gearbox.
On the brighter side it could just be that the cable has popped out of the box, there is only a tiny clip holding them in I think.
phew! just been to the car and that speedo thing on the gearbox had popped out, pushed it back in and its fine :)
mg_zt_t
Should not do that ~ they are either a screw fit or on early cars, retained by a spring clip which locates into a slot and locks the electric transducer in place.
ok well it keeps doing it so im going to get it looked at this week.
cheers
john
could this idicate a worn diff?
hi ,
just had another quick look at it and i pulled it and the whole transducer thing popped right out.
i popped it back in but im wondering if the spring clip has been damaged by my mechanic when he has taken it in/out ?
any ideas? or is this my diff dieing?
thanks
john
rover_600
diff dying starts with oil leak from passenger drive shaft & too much play in shaft.Would take it easy with 100k on clock as its probably ready to go
Discussion Starter · #8 ·
no, oil is fine no leaks at all, and i just put some new mtf 94 in, box is makes no noises what so ever.
when i drained it, the gearbox oil level was to the top.
rover_600
speedo drive is supposed to be held in by a bolt if I remember rightly,will just jump out all the time if missing-I had to buy a new speedo drive when I did box because I broke the top half of electronic sender-they break easy so be careful
1 - 9 of 9 Posts
