1 - 5 of 5 Posts
Hi Guys, can someone tell me what the max depth is that can be used in the doors? If I recall they will take between a 6 and 7 inch speaker (6.5 being ideal), but how deep?
~Nat~
depends if you use the original plastic mounts...yuk or make some custom mdf one, the 75 is a deep old door so i think most if not all 6.5 speakers will fit
I noticed behind the original speaker is a black membrane, presumably to keep water on the right side of the door.
Do people open up the membrane so the speaker has the door cavity to resonate in, and if so, how do you deal with water getting into the car?
as this membraine is a foam i think its more of a soundproofing than a water barrier....mine has been cut for nigh on a year now with no ill effects
1 - 5 of 5 Posts
