spannerking
922 Views 2 Replies 2 Participants Last post by  spannerking
I have just replaced the brake master cylinder on a metro 100 also rear cylinders, all bled correctly and pedal is hard but , as on other metros i have owned the pedal travel is excessive . is there any sort of adjustment on the pushrod ? the rear brakes are adjusted up and clamping brake hoses one at a time or all together makes no difference, can anyone shed a bit of light here ?.
If you pop the master cyl. off the pushrod in the servo adjusts out, you have to be carefull that the brakes don't bind when hot so do it a bit at a time.
Thanks for that, i'll give it a go this weekend, you learn something everyday!
